1 - 20 of 21 Posts
Sebring 6G72
As some of you know i have a RIPP SDS modified into a Sebring engine bay. And swapped to the same engine as you guys. Only i run different sensors/manifolds/ecus. Since i dont get to use a BB or GB tuning is left to other methods (SMT6 or AFC and MSD 6BTM). So its interesting to see how it runs on your cars compared to mine.
So with that said,
What is your intake temps for those of you that are boosted without any type of cooling(intercooler/meth)? Cruising temp? Max temp?
and while your at it you can add in intake temps for cooled charges and what psi you run.
Thanks
i ordered some hvac temp guages a while ago to monitor intake temps but they never arrived.
Sebring 6G72
Oh i didnt know you guys didnt have an intake temp sensor other than the MAS.
Yea i definitly need it from someone who is blowing through their MAS or has a sensor after the blower.
Let me know guys.
well you can spitball your inlet temp assuming you know your boost level and ambient temp...
you know what... its a pretty beefy equation, especially when you take into count the humidity... lemme toss it into a php script. gimmie a few.
Sebring 6G72
yea i am more interested in actual numbers...
but if you got the equation that would be cool too..... i would assume some of the heat has to do with the heatsoak. SC being mounted to the heads and next to the coolant pipes.. above the exhaust manifolds. Many things.
But when i drive at night my temps arent that much lower.
I cant believe most of you guys dont datalogg. That is just plain scary.
lol i never got around to starting, ill see if i can implement it tonight
Tout = Tamb + (Tamb * (-1 + PR0.263)) / comp efficiency
well you can spitball it like this
(ambient temp / ambient pressure = boosted temp / manifold pressure)
ambient pressure = 14.5psi minus .5 psi for every 1000 feet above zero
manifold pressure = ambient pressure + boost
ambient temp = duh
you can divide that by the compressor efficency to get a more accurate number
basically it spits out
100 degrees in and 10 psi boost = 169 degrees at 100%
or you can add 7 degrees per psi of boost, which is throughly inaccurate but a ballpark.
Sebring 6G72
Discussion Starter · #16 ·
so none of the people with regular SDS kits have ever datalogged their temps or fuel trims?
i really want to know what kind of intake temps they experience during cruising and boost.
cmon guys plug that laptop in and learn about your cars
Sebring 6G72
Discussion Starter · #18 ·
well i found some info from 2003 from RIPP about their intake temps...
they claimed that at 5psi they were seeing 187 degrees and 9psi 287
that is insane for the 9psi...
i dont quite understand why in a 4psi of difference it would raise 100 degrees
using any calculation from Combustibles equations i cant figure how?
I live in texas.. its 90 today with 50% humidity today.
Kampfbereit
The act of merely compressing air heats it up. It could be that going into 7~8psi is the threshold for keeping down the intake temps that necessitates a requirement for intercooling your boost rates.
Sebring 6G72
Discussion Starter · #20 ·
yea i hear ya...
i just think that if the intake temps are 187 at 5psi.. then at 0 psi you are looking at 145. when going into boost and the meth starts spray the temps will drop alot.
but on an intercooled setup you are looking at like 10-20 degrees over ambient temp... so that puts you at like 100 degree intake temp.. and whatever it will rise during boost.
so then it is safe to say they both work equally for temp drop... but you might get better gas mileage with the high intake temps? cleaner burn?
1 - 20 of 21 Posts
