1 - 2 of 2 Posts
I'm thinking about getting Monroe Quick Struts for my 2000 3g GT. Do I need to do that or should I just replace the struts themselves and reuse the original springs?
Administrator
Moved to correct section. Please look where you're posting next time.
I'm not sure what you mean by "quick struts". Unless you mean they are pre-loaded with their own springs. That's usually no issue and is alot easier. Just make sure the springs are rated the same as OEM.
From past experience, the best strut/shocks you can get for an OEM swap is the KYB GR2 struts/shocks. They are good oem replacement for oem springs. You can always get KYB AGX struts/shocks if you want a lower spring.
1 - 2 of 2 Posts
