Hey all!
Been in a bit of a pickle here as im currently trying to fix an issue that the previous owner created when he last worked on the car. Included is a picture that is highlighting the line that seems to be leaking all of my power steering fluid. When i had bought the vehicle the PS pump did not have a belt attached, after I had attached said belt the power steering was fine until the fluid began pouring out of the point i have highlighted in the image below. from what i see this is a return line and i think just has a rubber hose with no special fitting that joins to the line that runs to the cooler afterwards. My only problem with this is that the location of what i have highlighted is right behind the sub-frame against the firewall. I have removed the rear engine mount to get better access to it but i think the rubber is so old that it feels too stiff to move. Should i just buy a new line for this or will I need to drop the sub-frame to get/replace this line?
I would like to note that it is right near this section where the two hoses are clamped down. Because this is a return hose i was looking at the rock auto part (SUNSONG 3405063 )
Im certain this is the correct part but how should i go about doing this? just replace the old one since the rubber feels to tough to move with pliers?
