1 - 8 of 8 Posts
horrid advice. if you got a hole in your rad then pony up for a new one and pay the $100 for the tow. thats A HELL OF A LOT cheaper than a new engine because your pepper and egg didnt hold out :rolleyes:
Hola
I just like how in the bottom where it has "related" links, one of them is how to change the highbeam on a 94 honda......
Additional Instuctions:
1. If leak persists, then you probably have a unicorn in your radiator jumping around poping holes.
2.Therefore you will need to get rid of that,thank god everyone knows that unicorns fall weak and die when exposed to enough Human Fieses and Urine.
3.So begin saving up in a big enough bucket! ( i recommend GladWear the safest way to avoid a leak:bigthumb:)
4.Now, let the unique liquid flow into the radiator and leave running for an hour...The leak should either stop or not stop and you will smell like a 4000lb toilet.
5. ENJOY:sam:
G
rather than use an egg or that crap that people buy, looks like grey poupon, supposedly stops a leak, just turn the cap to that first safety lock spot so the system won't pressurize and u can get home to change the radiator. hey, it works.
1 - 8 of 8 Posts
