Shake/vibration in the steering wheel?
I can feel it in the gas pedal....only during acceleration. Then it feels like the whole car is vibrating.Ty said:Shake/vibration in the steering wheel?
Even if it is a drriveshaft problem, and I replace them(halfshafts) they will still be the same length.....therfore I'll still have the same problem right?ASTMedic said:If I'm not mistaken when viberation is only during acceleration it's usualy a drive shaft problem cus it's under a load but I could be wrong.
LOL there IS a camber kit in the rear....but the guy that did the allignment didn't tighten the bolts enough, and on the way home I hit a pothole...now my steering wheel is off center...I'm pretty sure I heard the camber kit come loose....hmmm and he wrote out right in the recipt NO WARRANTY ON LOWERED CAR so I can't take it back to him.....blkkamikazegs said:looks like you need a camber kit on the rear! Bad.
I assume you mean on the shocks...umm I used kyb gr-2's(non adjustable) not the kyb agx.....what setting are you on?
Lmk if you find that link. All I remember is that axles and/or stock struts may wear faster when lowered. I'll be lowering mine soon, so any "trick" that prevents premature wear would be helpful.There’s an answer for this that I saw something about putting some washers on the drive shaft will fix the issue, I can’t find the thread now, help me look if you would and link it. I can’t remember what I was searching but I do remember is was someone else quoting @Silvertune to put the washers there when the car is lowered because the shake is from the driveshaft being misaligned somewhat after we lower these cars. I link it if I find it because I am having this issue now and know the answer is here somewhere. I saw it already once.
