I have a chrysler Sebring LXi, 2001. Its has a 3.0L V6. It is the same as the 2001 eclipse gt 3.0. I have done everything possible to get this car fixed. I have no engine light but yet the car has no power. I water locked my motor a year ago and it has been giving me the same problem ever since. No one can tell me what is wrong with it. I have replaced the MAF sensor, the crank sensor, the harmonic balancer, the MAP sensor, new air filter, new EGR Valve, fresh tune-up, wires,plugs, and distributor. Any ideas would help. The motor was fully taken apart by three garages. The compression is fine, all gaskets are new, the valves and pistons are fine. I have no idea what would be causing this.
The main problem is the. The car has absolutely no power. It struggles to get up hills and when you step all the way on the throttle the motor bogs instead of taking off. It seems like it is getting too much gas. The other thing that gets me is that the car eats gas like crazy and like it never did before. Idk what is causing this or what else to even try to fix it. And help would be great.
