1 - 12 of 12 Posts
My malpassi FPR came with SDS kit starts leaking. I sealed it, good for a day then leaks again, did this like 3 times, I can see fuel buble out from one of the lower screew. I wonder if I can ask Ross to service this thing (=down time=sucks) or replace it with better one, but I'm not sure the alternate of this. Any suggestions from you guys?
Discussion Starter #4
I used teflon paste too actually. but doesn't help. Whats the alternative? does vortech FMU work the same?
Discussion Starter #6
Thanks for all the replies. I re-teflon each screw and apply seal glue I got from autozone. Checked it last night, this morning, everything dry. :twothumb:
Discussion Starter #7
OK, after 2 days, checked again this morning. Fuel slowly drips from the fpr. I'm really sure it was teflon pasted in all threads + sealed with glue. I need to replace this. What is the alternative beside Malpassi FPR with better quality ? .. a link to a shop will be better. Thanks guys.
Discussion Starter #8
No comment anyone? .. the vortech FMU is raising rate FPR, it has ratio like 8:1, 10:1, and 12:1 (=> is this 12psi of gas vs 1psi of boost?). Which one is suitable for SDS stage 1 (<7psi of boost)?
check this place out http://www.bellengineering.net/Pages/products_FPR.html
you would need part #2025. They are pretty good, I just installed mine yesterday and it works fine with the SDS. You can adjust base fuel pressure and it's adjustable rising rate from 1:1 to 12:1 if I remember correctly form when I talked to them.
Discussion Starter #11
Thanks guys
After reading this thread, I'm not sure which FMU I should get because I use RC 310cc. I think I will try this BEGI FPR.
so pacoslant, with this FPR what else do we need to do beside setting the idle pressure? how much pressure do you get at WOT?
Becak said:
Thanks guys
I set my FP at 50psi (idle) then there's another screw that regulates the rising rate, right now I have it set in the midle. The only acuurate way to set this would be at a dyno to make sure you have the right rate, I am going to the dyno next week, but everything seems to be fine. I don't think that thread aplies to us since we have the RIPP black box. I would think I get about 80-85 psi at WOT, but I'll let you know next thursday after I go to the dyno. If you have nymore question let me know.
PACO
1 - 12 of 12 Posts
