Prokit post from last year.........
I decided to go ahead and install the pro-kit springs this weekend to see how they perform—that way I can evaluate each suspension upgrade individually (springs, shocks, tires, rear strut tower bar). I went to Home Depot to pick up 15-40lb bags of sand, for 600 lbs total for my experiment. The general idea to the experiment is to measure spring rate starting from a normal resting position on the stock and pro-kit springs. The goal was to place additional weight to on the car and measure spring compression in order to approximate spring rate under real progressive force. Placing varying weights on the car, I measured total compression first on the rear, then on the front. Here are the results:
-all inches were converted to decimals to do the calculations
-measurements do not account for possible tire compression
-measurements do not account for minimal weight transition to front/rear of car as weight was added, for example of the 600 lbs. Of weight added to the rear, it is impossible to say exactly how much was transitioned to the front springs.
-my assumption is that the bags of dirt/sand from Home Depot actually weighed 40lbs each. I was not inclined to check it.
-measurements were taken at the wheel well, centered vertically on the center of the rims.
Rear STOCK Measurements:
0 lb. L/R average height = 27.34 inches
400 lbs. L/R average height = 25.79 inches
600 lbs. L/R average height = 25.07 inches
Rear Calculations
From 0lb.- 400lbs., k=f/x = 400/1.55 = 258 lb/in or 129.03 lb/inch per spring
From 0lb – 600lbs., k=f/x = 600/2.27 = 264 lb/in or 132.15 lb/inch per spring
From 400lb – 600lbs, k=f/x = 200/.72 = 277.8 lb/in or 138.8 lb/inch per spring
Conclusion:
Spring rate for STOCK REAR SPRINGS are about 130-140 lb/inch and seem slightly progressive—but unsure.
Front STOCK Measurements:
0.0 lbs. L/R average height = 27.41 inches
320 lbs. L/R average height = 26.44 inches
480 lbs. L/R average height = 25.94 inches
Front Calculations
From 0.0lbs. - 320lbs., k=f/x = 320/0.97 = 329.90 lbs/in or 164.95 lbs/inch per spring
From 0.0lbs. – 480lbs., k=f/x = 480/1.47 = 326.53 lbs/in or 163.26 lbs/inch per spring
From 320lbs. – 480lbs., k=f/x = 160/0.5 = 320.0 lbs/in or 160.0 lbs/inch per spring
Conclusion:
Spring rate for STOCK FRONT SPRINGS are about 165 lbs/inch and are not progressive
Eibach Prokit Install:
Total drop was about 1.2 inches in the front and rear. I drove the car hard to settle it in, and the car had been on the springs for a couple of weeks anyway..
REAR Eibach:
Placed 200 then 400 lbs in the rear and came out with around 135 lb/in for both weights, so the REAR Pro-Kit is NOT PROGRESSIVE and about the same stiffness as stock (probably about 140 lb/in).
FRONT Eibach
I placed 200, then 400, then 480 on the rear and was AMAZED by the results. Even with 480 lbs on the front end, measured compression was only .87 (less than an inch on both sides). The ratio was constant, so I do not believe they are progressive. But do the math – 480lb/.87 inch = 552 lbs/inch or about 275 lb/inch per side. If you doubt it, try it. I did it a couple of times and it came out in about the same range. That’s a pretty huge difference. I did all measurements exactly the same, so I don’t know what to say. Could it be 275? That would make the fronts 65% stiffer than stock. I have no problem believing that, because that’s the way it feels. What do you think?????
From 0lb – 400lbs., k=f/x = 400/.74 = 541 lb/in or 270 lb/inch per spring
From 400lb – 480lbs, k=f/x = 80/.13 = 615 lb/in or 308 lb/inch per spring
From 0lb – 480lbs, k=f/x = 480/.87 = 552 lb/in or .276 lb/inch per spring
Rear Calculations
Conclusion:
Front Calculations
Conclusion:
REAR Eibach:
FRONT Eibach
