1 - 2 of 2 Posts
got an 02 eclipse gt prm, i have a check engine light on for a misfire in cylinder 6, i did a minor tune up replacing the spark plugs, and it was still there went somewhere else and did a major tune up replacing all spark plugs and wires with ngk one's, but still i get a check engine light for a misfire, the guys @ the shop say i have an electrical problem, which i do but as far as i kno it only has to do with my aftermarket headlights, any ideas what else could cause the misfire in cylinder 6 if there is 1
Check the compression first. Cyl 6 is the one on the very right on the front head.
The causes:
Fuel- injector/wiring failure
Spark- plug/wire/distributor not giving spark/proper spark
Compression- low compression causing misfire
1 - 2 of 2 Posts
