41 - 55 of 55 Posts
Discussion Starter #41
So, I got mt battery tray reinstalled and soaked all the bolts I can see for the motor mounts and tranny bellhousing for anticipation of my soon engine install when I noticed the fender liner on the backside of my transmission is missing or maybe never existed. My gripe is i can see the backside of my wheel from the top of the engine bay. Is this normal for 3Gs?
Discussion Starter #42
I just installed mine..
The flat end should be on top when you mate them together.. you will definitely see the huge different.. the shifting is more precise.. best $10 upgrade..
Drove my car just around my buddies shop yard and I can already tell a difference in the shifting. I am convinced my shifting problem was the bushings all along
If you have time, change the clutch fluid and you will feel how much better the transmission is...(y)
Discussion Starter #44
Funny you mention, I bought a new sla e cylinder and hydraulic line when I do my engine. The old look really bad the rubber around the push rod is just before splitting.
Did you change them out? Change them and you will feel the different.
Low and Slow.
My transmission liner was missing when I got my car. Two bolts hold to the frame of the car at the top, and push button clips secure it to the main fender liner. I believe they are all the same between 4cyl/ 6cyl and auto/ manual transmissions. Local junkyard had it for cheap.
Discussion Starter #47
That sounds like what I am missing. It looks like road debris could easily be kicked up into the engine bay. If I get time this weekend, I have a pull a part near me that has a few 3Gs. I am assuming Stratus/Sebring would be the same? Maybe Galant
Low and Slow.
Im not 100% sure about the Galant, but I pulled one from an Eclipse for my Stratus coupe and it was a perfect fit.
Discussion Starter #51
Has anyone used the Glowshift gauges recently? I cannot stand not having an oil pressure gauge so I am adding this and a volt gauge to a double gauge pod. I do not want to buy the sandwich plate adapter if I don't have to. Anyone know fitting to buy to keep the oil pressure light while adding a gauge? I just ordered some fitting from McMaster so, I am assuming they might have something that would work. Tinted 7 Color Oil Pressure Gauge
Discussion Starter #52
Ok, so I am assembling what I call the coolant manifold on my new engine. Is their suppose to be a gasket along with the rubber seal for thermostat housing or just the rubber ring that fits around the thermostat? I feel like I am missing something here.
Low and Slow.
The rubber O-ring around the thermostat is all that seals the thermostat cover. Nothing else is needed. You do need a sealant when you connect the entire housing to the cylinder head if you took it off though.
Edit- Looking at the service manual for the V6 there are two gaskets the connect the entire housing to the motor.
Discussion Starter #54
I have the gaskets. You need sealant too?
41 - 55 of 55 Posts
