41 - 60 of 92 Posts
Discussion Starter #42
Got ahold of merlin, and got xml file yay!!
Changed out under hood shift bushings to soild mounts feels a lil better
Found out that the strut bar I modified to use the torque damper broke. So i remived both of them. Going to look at one once my motor is swapped. Until then i might get a stocker.
Got the porting of the heads and intake manifold started
Also painted some brackets black.
TxTuning.com
Good stuff. Don't be intimidated by the number of tables that are there. Just like on the WRX/EVO, there are many you'll never even touch. You'll pick it up with time, just take it easy, and get help whenever you question changes that you are unsure of.
Discussion Starter #44
Oh yeah, it's intimidating now but if i seen it a year ago...idk what i would have thought haha yeah. Ill learn it. Slowly but surely
Discussion Starter #48
So an update: the old motor is out. Pistons where wro g so sent them back. They just got back today.
Motor should be done this weekend
Looking for a place to fo my lsd swap in the tranny
Got my BHM adaptor
Lots of fun going on!!!
The Ghost
Why do you need a place to install your LSD? It's not like it's difficult or anything. Plus, there is a how to on this site if you're the type to need to follow instructions.
Discussion Starter #50
Yeah. I found it. And we'll probably going to need to do it myself. Just thought it was harder than it sounds...i could do it
Discussion Starter #51 (Edited)
So did some prep work thos weekend for the 3.9 swap. Got the tranny diff swapped. Used the how to on here and pulled it off in a single day. Sealed it up and will find out how good i did once its in. But shifts and looks good.
Discussion Starter #57
2000 eclipse GT with 3.86l
Exterior:
Modified GT style JDM rear spoiler
Staggered Avid 1 Av06 wheels 18x8.5 18x9.5
Vertical doors.
Debadged
Alloy gas door
Lighting:
Stock 00-02 rear lights vht blacked out
Ebay front dual halo with custom rgb color halos
Performance:
Built 6g75 Mivec 3.86
Custom wiseco forged pistons
Forged spool import h beam rods
Acl rod/main/thrust bearings
4 bolt main ARP studs
Cometic head gaskets ?.045
Full port and polished head and upper/lower intake
Gsc 2jz Viton stem seals
Modified 74 fuel rails
Fuel lab mini FPR
Comp stage 3 clutch
Wavetrac LSD
Fidanza Flywheel
Gates timing kit
Ac delete
Full blown 70mm evo TB
Under hood soild shifter bushings
RPM Window switch for mivec
Mishimoto radiator
Invidia n1 catback
BHM MIVEC Adaptor
Ngk wires and plugs
Suspension:
D2 coilovers
St susupension 22mm rear sway bar
Dc sport rear upper strut bar
Megan adjustable toe and trailing arms
Rear megan subframe brace
Ploy mount bushings
Interior:
Full tan to black swap
Black wrapped headliner
Blue led swapped 03 face dash
Sony dvd touchscreen
NRG- carbon fiber steering wheel with blue quick release
Nrg blue harness bar
Nrg tear drop CF shift knob
Ploy base ploy shift bushings
Red recaro Srt bucket seats
Blue speed sick harness
5 wide panel rear mirror
Full custom rear sub box with JL 12s and 600watt amp
3 gauge pod with volts,oil pressure, vacuum witch will be swaped for wideband soon
Small details:
Evo p/s res.
Boston hatchers rad support brackets
Non remote clutch res. No more remote cup.
Injen fuse box cover
Braided fuel lines.
Discussion Starter #59
So in VA. Been busy finally orders a new knock sensor. Doing that this weekend (i hope) pray for me.
And as for next plans. Going AEM standalone :) for the simple facts of
Live tuning
More support with tuning
COP
2 step.
Better knock control.
Once boosted it will help alot.
And lots more than stock.
I know stock ecu can handle what i could use, with talking to the right people. But i want to be different
Discussion Starter #60
Not letting me add pictures...but i picked up a pse6766 :)
ETS intercooler, some 550cc wrx pinks, hallman boost controller
41 - 60 of 92 Posts
