61 - 80 of 92 Posts
Discussion Starter #62
Welp been a while.
Have had the car tore down and slowly building back up
Wiring:
So i removed the stock ecu, stock engine harness and got it all tore down, slowly rebuilding and running the wires. I am going to be using a Mil spec firewall plug.
The fuse box was moved to under the dash
Cooling:
So i took out the heat so I removed the heater core, all the way to welding the ports on the thermostat for that.
Wanted to make as much room in the bay as possible so i got some pusher mishimoto slim fans. Have a standalone Fan controller for that. Got some mishimoto silicone hose and the 1/8 bung adapter for the sensor.
Gauges:
So i have now an Aem tru boost, AFR/ digital temperature gauge.
The temperature gauge is mounted in the stock location
The other two are now in the vents on the center bezel
The sun roof was deleted and sealed
The ABS was deleted and replace woth braided lines.
Discussion Starter #65
Well things have been moving along nicely!
Car is at the fab shop.
So what do i do in the mean time...plan and collect parts for AWD!!!
Some things i have picked up are listed-
Evo 8 5 speed trans
Evo 6 Tcase
6160 aluminum for a adapter plate
Evo 8 front axles
Evo 8 front knuckles
Evo 8 front wheel bearings and hubs
2G Gsx Rear subframe
2G Gsx LSD 3.307 rear Diff
2G Gsx rear axles
2G Gsx rear knuckles
2G Gsx rear wheel bearings and hubs
3G Megan racing trailing arm
3G Megan racing toe arm
3G ST rear Sway Bar
Band new Diff bushings
Soild subframe mount bushings
All Ploy knuckle bushings
All new End links
Brand new E Brake Pads,hardware and cables
1: I found a rear subframe about 3 hours away, drove up there and picked it up.
It was in rough shape as bushings and axles go.
Got it home and tore it down.
2: The axles where stuck in the hubs so i looked for new ones...yeah thats harder than said.
So i got on to the Drive shaft shop and found replacements. So i will be replacing them and the Boots.
3: The 75 to evo trans plate. I have been doing and redoing the adapter. And have ordered the aluminum so we will see how that turnes out.
So im just waiting on parts to come in. And will keep you up dated.!!!
Discussion Starter #67
Any updates on this? It would be nice to see an AWD MT V6.
Yes update.
The rear Gsx subframe is mounted with Tube Volk craft control arms, toe and trailing arms
The rear axles were rebuilt
Brand new OEM wheel bearings
Rear frontline fab diff cover.
I have the custom Driveshaft here
The adapter plate was made and and mounted and the trans tcase is mounted. I had to trim the front subframe to fit the Tcase.
I have a fuel cell with dual 450 E85pumps
As far as the car. Due to fab shops being shitty here in VA it took a while but the car is at a Fab shop getting turbo stuff done.
One i have it back i will be doing the rrest over the winter.
For more updates and pictures
@stanced_3g on IG
Discussion Starter #69
Great build! I also found you on YT in the meantime, keep it up <img src="http://www.club3g.com/forum/images/smilies/yesway.gif" border="0" alt="" title="yesway" class="inlineimg" />
Channel videos have been slow due to not having my car...but once its back. Ill be doing more with it
Discussion Starter #70
Update parts list.
**ENGINE BAY**
*MOTOR*
3.9L V6 MIVEC
Wiseco 96MM Pistons with 1MM over sized Valve pockets(.0045 piston to wall)
Spool Import H-Bean Rods with ARP 2000 Bolts
VR4 ARP 4 Bolt Main Studs
ACL Main STD Bearings
ACL Rod STD Bearings
ACL Thrust Washer
Cometic .045” Head Gaskets
Blocked Zero Deck
P&P Heads
Gasket Matched intake manifold.
S90 74MM Tb with evo sensors
GSC 2Jz Viton Stem seals
Custom 6G74 fuel rails
SpeedFactory 2JZ Titanium Exhaust manifold studs
*COOLING*
Mishimoto Alum Rad.
Mishimoto Blue Silicon hoses with 1/8th Adapter Bung
Mishimoto Dual Pusher Fans with Electric Fan controller
Boston Hatcher Rad support mounts
*TURBO*
Twin scroll 6766PTE
EVO ETS Front mount intercooler
Duel 38mm Tial Wastegate
Tial 38mm Bov
Full custom turbo “kit” By Limitless performance
*Fuel System*
Custom -8 SS Fuel Feed
Custom -6 SS fuel Return
1200cc injectors
Fuel lab FPR
AEM Flex Fuel Sensor
Walbro 450 pump
12gal Radium fuel Cell with dual 450 E85 Pumps
Radium 100m inline fuel filter with heat exchanger mount
*ELECTRONICS*
AEM V2 VR4 ECU
FULL Custom Wire Harness
Motec Firewall 61 pin Plug
AEM Oil Pressure sensor and Gauge
AEM Coolant Temp. Sensor and Gauge
AEM Tru Boost with Boost Sol.
AEM AFR Gauge
*ODD and INS*
ABS Delete
Cruise control Delete
Evo Stainless steel power steering reservoir
Battery Relocated
Fuse Box Relocated
**DRIVETRAIN**
*AWD*
Evo 8 Trans
Custom Adaptor plate to fit evo trans on v6
Evo 6 T Case
Front Evo Axles
Front Evo Knuckles
Front Evo Wheel Bearings
Custom 2 piece Driveshaft from Driveshaft shop
Rear GSX Subframe
Rear GSX 3.307 LSD
Rear GSX LSD Axles
Rear GSX Knuckles with Poly bushings
Rear GSX Wheel bearings
Rear GSX rebuilt Parking brakes
Rear Soild Subframe Bushings
Boston Hatcher Duel Diff Mounts
Evo SS Full Slave cylinder Line
Rear Volk Lower Control Arms
Rear Volk Trailing Arms
Rear Volk Toe Arms
Evo Soild shift bushings
Rear 3G upper control arm
3G D2 Coilovers
Rear upper DC sport strut bar
Full EVO Brembo Swap finished in Race Red
Stop Tech Slotted Rotors
Evos extended lug stud all 4 wheels
15mm STM Wheel spacer
GoodRidge SS Brake Lines
Clutch masters Twin Disk with custom Flywheel
CM Hydraulic throwout bearing
CM Hydraulic flow control valve
**BODY**
Stock body
Alloy Gas cover
Avid one AV-06 wheels
18x8.5 +35
18x9.5 +24
Sun Roof Delete custom cover
Front and Rear Windshield wiper Delete
Spare Tire tube replaced with custom Fuel Cell Box mount
**INTERIOR**
Megan Racing Short shifter
NRG Quick Release
NRG Carbon Fiber steering wheel
NRG Tear Drop Carbon Fiber Shifter
NRG Harness Bar
5 point Harness
Red Fix Back Recaro SRT Seats
full Rear interior Delele
Discussion Starter #74
ENGINE BAY
MOTOR
  • 3.9L V6 MIVEC
  • Wiseco 96MM Pistons with 1MM over sized Valve pockets(.0045 piston to wall)
  • Spool Import H-Bean Rods with ARP 2000 Bolts
  • VR4 ARP 4 Bolt Main Studs
  • ACL Main STD Bearings
  • ACL Rod STD Bearings
  • ACL Thrust Washer
  • Cometic .045” Head Gaskets
  • Blocked Zero Deck
  • P&P Heads
  • Gasket Matched intake manifold.
  • S90 74MM Tb with Evo sensors
  • GSC 2Jz Viton Stem seals
  • Custom 6G74 fuel rails
  • SpeedFactory 2JZ Titanium Exhaust manifold studs
COOLING
  • Mishimoto Alum Rad.
  • Mishimoto Blue Silicon hoses with 1/8th Adapter Bung
  • Mishimoto Dual Pusher Fans with Electric Fan controller
  • Boston Hatcher Rad support mounts
TURBO
  • Twin scroll 6766PTE
  • EVO ETS Front mount intercooler
  • Duel 38mm Tial Wastegate
  • Tial 38mm Bov
  • Full custom turbo “kit” By Limitless performance
  • Vibrant HD intercooler clamps
  • Turbo Guard Turbo Blanket
  • Turbo Guard compressor screen
Fuel System
  • Custom -8 SS Fuel Feed
  • Custom -6 SS fuel Return
  • 1200cc injectors
  • Fuel lab FPR
  • AEM Flex Fuel Sensor
  • Walbro 450 pump
  • 12gal Radium fuel Cell with dual 450 E85 Pumps
  • Radium 100m inline fuel filter with heat exchanger mount
  • Custom 3 relay panel
ELECTRONICS
  • AEM V2 VR4 ECU
  • AEM CD-5 Dash
  • FULL Custom Wire Harness
  • Motec Firewall 61 pin Plug
  • AEM Oil Pressure sensor and Gauge
  • AEM Coolant Temp. Sensor and Gauge
  • AEM Tru Boost with Boost Sol.
  • Dual AEM AFR Gauges
  • Front mounted battery kill switch
  • AutoTac fuel level Gauge
  • Evo8 Speed sensor
  • Montreal Cam sensor wheel
  • OMIN 4Bar Map sensor
ODD and INS
  • ABS Delete
  • Cruise control Delete
  • Evo Stainless steel power steering reservoir -deleted
  • Battery Relocated
  • Fuse Box Relocated
  • PS Delete
  • Window wipers deleted
DRIVETRAIN
AWD
  • Evo 8 Trans
  • Custom Adaptor plate to fit Evo trans on v6
  • Evo 6 T Case
  • Front Evo Axles
  • Front Evo Knuckles
  • Front Evo Wheel Bearings
  • Custom 2 piece Driveshaft from Driveshaft shop
  • Rear GSX Subframe
  • Rear GSX 3.307 LSD
  • Rear GSX LSD Axles
  • Rear GSX Knuckles with Poly bushings
  • Rear GSX Wheel bearings
  • Rear GSX rebuilt Parking brakes
  • Rear Soild Subframe Bushings
  • Boston Hatcher Duel Diff Mounts
  • Evo SS Full Slave cylinder Line
  • Rear Volk Lower Control Arms
  • Rear Volk Trailing Arms
  • Rear Volk Toe Arms
  • Evo Soild shift bushings
  • Rear 3G upper control arm
  • 3G D2 Coilovers
  • Rear upper DC sport strut bar
  • Full EVO Brembo Swap finished in Race Red
  • Stop Tech Slotted Rotors
  • Evos extended lug stud all 4 wheels
  • 15mm STM Wheel spacer
  • GoodRidge SS Brake Lines
  • Clutch masters Twin Disk with custom Flywheel
  • CM Hydraulic throwout bearing
  • CM Hydraulic flow control valve
  • ARP Ford Probe long Flywheel bolts.
BODY
  • Stock body
  • Alloy Gas cover
  • Avid one AV-06 wheels
  • 18x8.5 +35
  • 18x9.5 +24
  • Sun Roof Delete custom cover with Ti bolts
  • Front and Rear Windshield wiper Delete
  • Spare Tire tube replaced with custom Fuel Cell Box mount
INTERIOR
  • Megan Racing Short shifter
  • NRG Quick Release
  • NRG Carbon Fiber steering wheel
  • NRG Tear Drop Carbon Fiber Shifter
  • NRG Harness Bar
  • 5 point Harness
  • Red Fix Back Recaro SRT Seats
  • full Rear interior Delele
Discussion Starter #75
so I have been doing a lot and little to the car since the last update so I don't know where I left off. BUT the car is about 99% done!!! the Awd is in and complete with the rear diff, T case and Trans. the Fuel system is all good. had to replace a line but that's all good. the ECU is in and wired up. we will see how good I am with that. I will be dropping the car off to get Tuned next month ( FEB2020) and they will do what they can to get it on the road!!
61 - 80 of 92 Posts
