1 - 16 of 16 Posts
Stage 1 SDS @11+ psi
Nice. Gluk with the build. I recommend going overkill with the gauges. You are boosting an engine not designed for it. The more monitoring you have, the better you can troubleshoot issues before your engine goes poof. The ones I got are: Boost/Vac, AFR, Fuel Pressure, Oil Pressure, EGT, and Oil Temp. The Oil Temp gauge is optional, but the others have been invaluable. I just can't say that enough.
I also use OBD2 monitoring for RPM, Absolute Throttle Pos, Engine Coolant Temp, Timing on Cylinder #1, and Engine Load. For all that I use BlueDriver OBD2 module and my iPhone. So good.
Discussion Starter #4 (Edited)
Thanks guys, I appreciate the support and advice. I plan on getting more goodies as the time passes on. My SP stg 2 meth kit came with a digital boost/vac gauge. I am not tech savvy by any means, what is a blue drive ob2 module? I just tried searching for the answer but came up short. Is that software? I haven't purchased software yet?
I'd recommend using AEM gauges (AFR, boost, oil pressure, etc) and staying away from cheaper brands like ProSport. After repeatedly replacing failed ProSport sensors I learned my lesson.
Discussion Starter #8
I completely agree, I would only use aem products as i trust them and have served me well in the past.
It looks like you're collecting parts for a non-mivec engine. Another recommendation is using a 3.8nm upper intake with an Evo 8 S90 throttle body. It's a much better flowing setup.
Discussion Starter #10
I have the xg350 intake manifold which is 126mm. I will take your advice on the s90 throttlebody tho. Currently I have the 74 throttlebody installed.
The 75nm intake flows better, weighs less, and makes more power. Also the S90 tb and 74 flange on the XG350 do not line up correctly. If you're not using a 75 intake then flange swapping isn't worth it.
Discussion Starter #13
Thank you for the advice. Ill hit my dad's salvage yard and pickup the mani asap. Should I grab the lower mani portion too or just the upper
Only the upper needs to be swapped. The 75 lower has the fuel rail tabs angled differently and won't work. While you're there try to find an 02-06 tps sensor for that S90 tb. It rotates the opposite way because of cable location on the tb.
Discussion Starter #15
We don't have any evos in our yard, but I did grab the 75nm up manifold. Too bad the 3.8nm had a snapped timing belt or i may have gotten the whole engine. Didn't want to risk pulling it just to have bent valves tho.
Oops looks like I forgot to put Outlander after 02-06. They have the same tps sensor as the evo 8/9.
1 - 16 of 16 Posts
