1 - 3 of 3 Posts
My speedometer ain’t working!!
I have replaced speed sensor, Speedo gear, and cluster it self and!! still does not work!!!
Any ideas? (well speed needle on cluster goes up some time to time at high RPM..)
Did you install glow gauges or a glow needle kit? My 1st guess is that you pushed that needle on too far. But if you are all stock then I don't have a clue what the problem would be. My 1st check would be the wiring that connects the speedo gauge to the sensor itself. I would try to ohm those out and make sure there is continuity and no shorts. Sounds like you have already checked/replaced all other items :dunno:
1 - 3 of 3 Posts
