1 - 2 of 2 Posts
I have a 2001 galant 2.4l with auto trans, originally the speed sensor is on the output shaft ( pretty sure). The trans went out and i bought a used one from a 2002. (It was cheap) trans shift and functions fine, the speed sensor however is supposed to be an input shaft sensor i believe. Is there a kit or some wires to splice somewhere to make the wire harness work with the new trans or am i just out of luck? Or am i just missing something obvious?
Any help is appreciated.
Ive read many forums about replacing the speed sensor or just locating it, but i cant find anything about changing from an output to input, or if thats even a thing.?
I've played with these transmissions a lot and if I remember correctly the internals are different, the gear and everything does not work. I'm sorry and also not 100% but I do not think it will work.
1 - 2 of 2 Posts
