1 - 7 of 7 Posts
HMRacing
I just bought a Jensen VM9311TS indash DVD player and once i got it hooked up it says i have to hook some wire up to my parking brake for it to work. I have installed many decks in the past but this is my first indash DVD player and i heard you can bypass the parking brake wire so you can watch the screen anytime insted of being stopped to watch it. Does anyone know how to bypass the wire or any code to turn it off. I used the ground and it came off but after i disconnected and turned the car off it wouldn't come back on.
Try This:
JENSEN bypass parking brake feature
ATTENTION TO ANYONE WITH A JENSEN VM9311,VM9411, VM9511TS and/or 9021TS
YOU CAN BYPASS THE PARKING BRAKE SECURITY FEATURE FOR FREE!!!! WITHOUT PAYING FOR THOSE PULSE BOXES OR ANY ADDITIONAL HARDWARE!!!!!
YES THE LITTLE BLACK BOXES WORK....BUT THEY'RE A SCAM CAUSE YOU CAN DO THIS FREE USING THE JENSEN FACTORY OVERRIDE CODE
So if that isn't clear enough, let me further explain. The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated
movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
HMRacing
Still confused there is no stop button on my remote control! I someone how it where it was working but i didn't get the code in.
wow i have this same unit and i just lift my e-brake up to the first click(it wont engauge) and i can watch them
I remember the first time I installed mobile video equipment in my car. The longest part was trying to figure out how to make it work while driving, and that part alone took about an hour and a half. (Not sure if ALL systems are like this, and Im not sure if this method will work for all systems but I just grounded the parking brake wire.)
yaaa i also have a jensen flip out and i have to say i hate it.. mine is hooked up through the e-brake and its wierd sometimes it works while im driving sometimes it doesnt, but then also sometimes it doesnt work at all soo im selling mine tomorrow and going back to my Stock HU..also quick question, anyone notice a difference in sound from the infinity HU ever sice ive installed my Jensen the audio sounds like crap anyone else notice this?..welll not really like crap but it was so much better with Stock HU and i miss it
1 - 7 of 7 Posts
