1 - 11 of 11 Posts
I'm installing underground lights to my 3g eclipse and it says I need to power it to a 12v source in the engine bay. Where would be a sufficient power source thats 12v that I could use to wire to
Will the light be run off a switch? If so, just wire it off the battery or a wire coming directly off the battery. However, you MUST include a fuse if you are doing this.
What does the remote control, control? I'd bet money it controls a switch. Connect to the battery with a fuse block and you'll be good.
Discussion Starter #10
thanks again for the suggestions I was able to check it and get it installed. Sorry, I completely forgot to reply it was ddone.but couldn't be happier with the results #3Gnation 😁
1 - 11 of 11 Posts
