MB526680 location in the CV assmbly
The above link shows MB526680 is the seal at the CV cup and CV axle assembly. Its not the inner seal that is included in Bearing - Mitsubishi (MR388567), and its not for 2000. Please verify?
This below link shows the OEM MR388567 which is consisted of the bearing and the inner seal.
https://www.wholesalemitsubishiparts.com/oem-parts/mitsubishi-bearing-mr388567
Do you know the part number of the inner seal? what type of seal is it?
I have the old OEM inner seal that I posted above. I can not picture how it fits into the bracket. Do you have a picture of completed bearing assembly that shows how the inner seal seats in the bracket? Or do you have physical picture of the inner seal?
This is nationa brand oil seal 51098 I bought, and want to use it as the inner seal together with the National Bearing 206-FF BCA bearing (
BCA Bearing) and
National oil seal part 51098. They both fit well inside the bracket but its re-assembly is corrected or not, you know?
The physical apperance of the national oil seal is not strong, and I am not clear if the inner seal can withstand the friction of the inner shaft rotation. I contacted the member of
Mitsubishi 3000GT & Dodge Stealth Forum who did document the national brand on the seal 51098. I wanted to know how long he used it his car?
Yes I had difficult in removing the stucked CV cup off the bracket . The inner shaft assembly was not bad after I took out 2 bolts like you said. The location of the bolts was kinda odd for me with the car on the stand jacks. I should have done like you said taking the stuck cv cup to be pressed out. I know there are more difficults ahead of me to install the CV assembly back to the car.
Yes I need to buy MIT OEM parts but they are expensive, and may not be available for my 2000 car. My original parts_ the shaft, the bracket, the bearing are still good to use I think but the seals are damaged during the disassembly process.
. Mit dont just sell the seals by themself but the whole kit. Its why I am looking for the aftermarket parts.
Yes I plan to replace inner shaft/trans. seal after I remove the old one. I want to use a new c-clip that I am not sure I can buy individually?
