need help
518 Views 1 Reply 2 Participants Last post by  MarkSpyder
i have an 01 gt that needs a new throttlebody and i need to know whats the best to get?
1 - 2 of 2 Posts
Best? How much can you spend?
Realworld I would suggest a 2002 Diamante's throttle body (with or without traction control but without would be ideal I think). It has the widest opening I know of... But you may have to swap in a Diamante manifold as well (which I recommend). I'm not positive if the TB's valve will open 100% due to the GT manifold hole being smaller. You'll get the max benefits (increased volume of airflow into the engine if I understand it correctly) by replacing both anyway. Shouldn't cost you more than $300 total. Maybe as little as $125 if you are not in a rush. There is a how to about the D's manifold and TB. Just search for it.
List your other mods, if any. And welcome to the club newbie! :wavey: I see this is your 1st post... :ubernin: Note: It should have been posted in "GT Specific" section of these forums.
1 - 2 of 2 Posts
