Need Some Help!
813 Views 7 Replies 5 Participants Last post by  MarkSpyder
Does anyone happen to know where its the safest to drill a hole through the firewall to get all my wires that go to the engine through the firewall if anyone knows I would very much appreciate your help...thanks in advance.:hbang:
1 - 8 of 8 Posts
Just run the wires through the driver side fender.
I used the fender for everything. From my wideband & EGT probes to 0ga stereo wiring. You can fit a TON of stuff through the pre-existing grommet. Remove the driver side splash shield to get a good view of it. Its hard to spot from the inside of the cabin without some light coming in through the outside (with splash shield removed).
i drilled a hole about 4 inches down and 2 inches to the left of the master cylinder. best spot that i found without hurting anything and not running it throudh the fender.
Yeah I have it going through the fender now and the wheelwell through the hole thats there but I wanna get everything nice and together through a dry place you know.
Wait bro I am not quite understanding from where you measured...Did you measure inside the engine bay?
:scratch: The fender is dry, assuming you have the splash shields installed. So, I don't think I know what you mean. :dunno:
If you do drill the firewall dont forget that a thick grommet is REQUIRED or you risk shorting out the wires passing through that hole!
1 - 8 of 8 Posts
