Are they DDM tuning head lights if so I have the same one and how you make the ring lights work because mine don’t work
No they're the Winjet ones.Are they DDM tuning head lights if so I have the same one and how you make the ring lights work because mine don’t work
ok thank you but my headlights are Similar is there more wiring you need to do to get the ring lights working
The halos should have separate wires that you have to hook up. I spliced into the parking lights so they will be on without turning on the headlights.ok thank you but my headlights are Similar is there more wiring you need to do to get the ring lights working
Do you have wires hanging underneath the headlights? A red and black wire? If so, you could either splice them into the parking lights or do what I did. I spliced the headlights together.. then ran a power cable to the inside of the car to a switch and then from the switch to a relay, to a fuse, then Hooked it up to the positive terminal. I spliced the black wires from the headlights together and ran the black cable to the negative terminal.ok thank you but my headlights are Similar is there more wiring you need to do to get the ring lights working
Watch my Video.. I explain how I powered the Halo'sHopefully you're running power through a relay and not directly through the switch.
I very much appreciate the help. I'm so not an electrician.. but I'm willing to make the necessary changes in order to halt any problems down the road. I would like to change halos for LEDs.. which means I'll have to bake the headlights. 😔The light output of those headlights is very poor and I have a feeling you will be looking to change them very soon. Depo headlights are the best available.
Also running wires around the hood hinge and through the door jam is not a good idea. Not only does it look awful but you risk broken wires and shorts. If you were to install the relay in the engine bay (possibly behind the driver's headlight) then you could grab 12v+ from the underhood fuse box and a ground from behind the headlight. Then you can have your switch provide ground to the relay to trigger it which gets you down to 1 wire between the switch and relay. You also don't risk electrical shorts if the wire were to break in the door jam. It's not much reconfiguring to do it this way. I can be more specific if you need help.
A 4 pin or 5 pin relay will work the same but for simplicity just get a 4 pin. Run a chassis ground wire to one of the posts on your toggle switch and run a wire from the other post of the switch to pin 85 on the relay. Then run a fused 12v+ power wire from the underhood fuse box that goes to both pins 30 and 86 on the relay. The last pin on the relay, pin 87, will run to the red positive wires of the halos. The last step will be grounding the black negative wires of the halos to the chassis.I very much appreciate the help. I'm so not an electrician.. but I'm willing to make the necessary changes in order to halt any problems down the road. I would like to change halos for LEDs.. which means I'll have to bake the headlights. 😔
I def would like reconfigure the setup how you're explaining
How they holding up ?Are they DDM tuning head lights if so I have the same one and how you make the ring lights work because mine don’t work
How they holding?
Can you shoot a link for those headlights?The light output of those headlights is very poor and I have a feeling you will be looking to change them very soon. Depo headlights are the best available.
Still working pretty good. I have to adjust the projectors downwards some but the halos still work. I only run the halos at night.How they holding?
Thanks man I ordered mine and had em for 3 days and a halo went out I was pissed
Did you hook them up to the parking lights?Thanks man I ordered mine and had em for 3 days and a halo went out I was pissed
