1 - 3 of 3 Posts
I’ve fully swapped in the manual tranny, and when I go to crank the engine over nothing happens, I’m fairly certain that I’m missing some grounds and that could be a big part of it
43952
there is still lots of buttoning up to do, but if I can just get it to pop off I will feel 100% better
You might check for power at the starter when you try to crank it. You could also tap (bang) on the starter in case it's stuck.
I added a frame to engine ground and it started working, however I think my timing is off now because I can’t get it to fire and I’m only making 50psi of compression so I’m taking the timing cover off tomorrow checking timing
1 - 3 of 3 Posts
