1 - 10 of 10 Posts
· Registered
Changed plugs, gasket, coils, egv and still it bogs down. Checked to see if there was a vacuum leak and I honestly thought the coils that came today would solve it.
I just want my little get up and go car back. Any ideas? I'm not mechanic but I know the basics.
Automotive parking light Wheel Car Tire Vehicle
· Registered
I would suggest you buy your own code reader and learn to use it. In my opinion, Auto Zone people are a bunch of "twits" that just want to sell you parts. If they were real mechanics, they would not be working at Auto Zone. In my experience, quite often what presents itself as a EGR problem is quite often an issue with the controls that operate the EGR, and not the EGR valve itself. These are not simple systems to diagnose. ...J.D.
Telephony Communication Device Telephone Automotive tire Mode of transport
Motor vehicle Gas Auto part Nut Automotive exterior
· Registered
I would pull the codes first, before you change anything. In your experimenting around, you may inadvertently cause another error code. You really cannot do much diagnostics on these cars without the code reader though. Read the codes and get back to us. ...J.D.
· Registered
update. So far I changed coil packs, wires, spark plugs, egr valve, fuel pressure regulator. Tonight I added some injector cleaner in the gas tank (seafoam)
Don't know where id go to get a pressure check. Oh and I cleaned MAF sensor. Put airflow and filter back together. Cleaned battery posts and tightened. I am bashing my head against the steering wheel which is annoying because my horn sounds like a clown car.
As of a young fella at O'Reileys... Misfire, gas circuit low, air temp sensor, air flow circuit lean, map sensor low, system lean. This was before the install of the fuel pressure regulator. So i guess I should see what it says on their machine tomorrow. Thanks guys for all your input. I'm an old guy but love this little car as it was the first car i sold in the US for mitsubishi in 2003 from England. So to have this group and forum is awesome. Always loved the 3g.
Wheel Tire Car Vehicle Automotive lighting
· Registered
2005 Spyder GT
Cleaning the MAF is NOT recommended on these cars bc the sensor is too sensitive.
As already mentioned, try disconnecting the MAF connector and note any changes in how the car runs.
Regardless, you need to find the source of the "sucking" sound leak. Manually move the throttle cable to increase the rpms while moving your head around between the throttle body and air cleaner to try to pinpoint the source.
Remove the air intake and inspect for cracks or holes, then reinstall making sure to tighten the clamps enough.
Replace the MAF if unsure of how old it is.
Try cleaning or replacing your upstream O2 sensor.
1 - 10 of 10 Posts
