21 - 23 of 23 Posts
Discussion Starter · #22 ·
Relax guys I did it just to test it out. Found out the real issue though. The fuel pump relays Were in the wrong spot. Per the service manual, it goes fuel pump relay (1), no connection, fuel pump relay (2). Well mine had both of them next to each other. Fixed that and put the wiring back to how it's supposed to be and it's all good now.
Sent from my iPhone using AG Free
Tapped into the fuel gauge power and ground. Car runs and drives now. Started up instantly. Idle was jumpy and it has a nasty tick but at least she's running now.
How did you fix the problem ? I’m currently having the same issues in my 02 eclipse. I thought about running it to a kill switch but I’m trying to at least figure out the real problem before I tap into hardness’s
21 - 23 of 23 Posts
