1 - 2 of 2 Posts
Hey everyone so I recently bought an 03 GTS that needed head gaskets and a couple other things. Long story short I have it all back together now and I go to turn it on it stutters and dies after about a second. Checked the codes and its throwing a bank 2 sensor 1 02 code buts that's because I forgot the EGR pipe gasket and a P0660 (Intake Manifold Tuning Valve) believe I fixed that one though since I missed 2 hoses going into the solenoid. Try to start up again and still stutters and dies. Itll only stay on if I pretty much floor it where itll then make some noise that sounds like a girl screaming or high pitched screaming. Checked timing again, crank and bank 1 are good and bank 2 is about 3/4 of a tooth off. Does anyone have any suggestions I'm lost on what to do now.
Aple juic is my beer
Check that you have the distributor on correctly as well as the wires on the right plug. Check all electrical connections.
1 - 2 of 2 Posts
