hello everybody,
i have this strange problem i spotted on my '03 eclipse. before going to details: i searched this forum for similar posts, but seems that i didn't found exactly why this is happening to my car, looks like it's not the common problems like evaporator's drain ac leak etc.
so i found that the driver's side (left) carpet is wet on the back (yes, not the whole carpet, but mostly the back where the passenger should put his legs and more to the left side near the door). i'm not really sure what is it and where the water comes from. there is no sunroof. seems there is no leak from any of the sides (the sides are dry, the bottom floor carpet is wet). also looks like there is no leaks from above like window or anything else - the rubber floor mat on the top is dry, only when you lift the floor mat you can see it's wet on the other side and the car carpet is wet. like i already wrote it's getting wet more on the left side of the carpet, not the whole left side carpet, but the left side carpets left side. the carpet under the drivers legs (pedals) is dry. oh yes, and it got wet when the car was not running, which means it stayed on one place, i wasn't driving it for the 5 days and all these 5 days it was raining, so in these 5 days of car staying at one place somehow a water leaked, so i'm really confused about this and where can it come from. so... any suggestions? i didn't had a chance and time yet to thoroughly check everything, lift the carpet and so on, so before that i would like to hear some of your opinions, suggestions what could it be, what to check etc. thanks
