1 - 9 of 9 Posts
well to start off I threw a engine code. went to get it checked and I was told the OBD2 port wasn't working to check the fuses. I checked all the fuses on the car and all of them were ok. I went to drive down the road due to having to go to work and if I went into neutral the RPM would fluctuate or just drop so low the car would die. Any suggestions??? Im kinda stumped on it.
It's good. Even put a new one in it
Discussion Starter #4
What else can I check? Also would the obd2 nt working cause the car to have random idling range and dying?
I replaced all the fuses with brand new ones. Still obd2 isn't working
Discussion Starter #6
no ideas guys?
Discussion Starter #8
forgot to post on here when the issue was resolved. there is a small box with a fuse in it on the positive post and it had some corrosion in it. one I cleaned that up the OBD2 started working just fine.
Reactions: Dannyritz
1 - 9 of 9 Posts
