1 - 1 of 1 Posts
so I'm sure this has been talked about and yes I've searched but didn't find the answers. So I have the td05hr turbo. The stock oil food and drain lines don't work obviously because it can't bolt to the head. So I need to find out if I need a restrictor fitting for the top to change it to -an or if I should buy the banjo to -an fitting. And there is 2 places I know of to feed oil. From the oil filter sandwich plate is where I plan to run it from since it seems like the best option. I'm not sure whether I need to have a restrictor fitting in the oil feed or not.
1 - 1 of 1 Posts
