1 - 2 of 2 Posts
I’ve had a leak that I am having trouble locating. When I take off passenger side wheel it seems this area is the worst so I am thinking it’s a leak in the timing belt side of the engine. If you look close in the first photo you can see a bolt hole behind the belt tensioner; is there a bolt missing and does that need to be sealed for oil to not be leaking? Any suggestions would be great. I have done the valve covers twice and cannot get the leak to go away😭. I am aware of the issue where the valve cover bunches up and gets pinched at the rear, this doesn’t appear to be my issue I have triple checked the valve cover gaskets. Thank you for any insight!!
Shoe Automotive tire Product Textile Wood
Automotive tire Wood Volute Automotive wheel system Gas
1 - 2 of 2 Posts
