Did you replace the seals after dropping the tranny?
Do yourself a favor and get a cheap set of calipers. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47256 With the calipers you will be able to measure the depth that the seals are pushed down from the surface. It is very easy to push the seals in too far. It is also very easy to put the seals in crooked. Both install errors could cause leaks or other problems, so be carefull.i will do thanks
So what all did you have to replace?thanks guys i've fixed the leak and finally no slipping clutch..by the way which o2's are bank 1 sensor 1 and bank 1 sensor 2
