anyone had any real tuning experience with this motor? i have a 2004 with a turbo kit and emanage ultimate. the problem i'm getting is that the factory ecu will NOT go out of closed loop even after 5 seconds at 7 psi. what that means is despite the amount of fuel i add with either the airflow adjustment or the additonal injector, the ecu is pulling it back out as quick as i can add it in. 14.7:1 air/fuel and boost do not make for lasting friends. this is the most likely reason for reading about so many engines blowing up. new subarus are this way too and they are factory boosted. however, after about 4500 rpm, they do finally switch to open loop and flood the engine with fuel taking it down to about 10:1 air/fuel. their timing would be setup for that though, so doing it here is not safe.
i'm wondering what others with dynos or extensive tuning with a wideband and obd 2 scanner have found. i did not take this car past 4500 rpm for safety.
this tune is on hold until i can find out more info. anyone?
tk
tk
