2003 GTS Spyder with 151,000 miles.
P0154 code been coming up for the last few weeks. That code is for the very top-front O2 sensor right below the TOP radiator hose.
Replaced the O2 sensor two days ago(with the battery unplugged of course), and now I have an P0155 code after driving it for over 200 miles.
Only comes up when I start the car.
I erase it, it comes back each time I start the car.
I believe that the NEW sensor isn't receiving a reading on time or something.
Has this happened to anyone before?
Any suggestions or solutions?
2005 Spyder GT
triple check that the sensor is the correct part number...I remember when I replaced mine that some websites had the part numbers mixed up.
Discussion Starter · #4 · (Edited)
Getting a pending code of P0157 now along with P0155, which is low voltage.
On my Reader app connected to the car it reads the voltage as 0.0% but reads something about the fuel just fine tho.
Perhaps I made the mistake of buying it from eBay for $25. It would be better just to connect the old O2 sensor and drive with that on until I can afford those Bosah O2 sensors...or are there cheaper ones, like from Rockauto to recommend?
The biggest problem with replacing OEM parts with aftermarket replacement parts is that they do not match the OEM milliamp voltage and through off the ECM readings, creating a code from it not reading correctly, causing misreadings leading to codes. The OEM 02 sensors should be cleaned or replaced with OEM parts and run a bottle of catalytic cleaner, CAT-Clean, Sea Foam, and injector cleaner after checking the spark plugs and wires or coils to make sure the motor is burning up the fuel correctly.
