P0401 EGR Flow Insufficient
3170 Views 7 Replies 6 Participants Last post by  jelazar
So I've been struggling with this problem for a while now and I don't know what else I could possibly check in the EGR system. I know there's been a million threads on EGR problems but I've been looking through most of them and all they say is "just clean EGR" or "Replace EGR" or "check your sensors" and I've literally done all that and can't find a single problem. My car is a 2003 Mitsubishi Eclipse Spyder GT 3.0L V6 with Variable Induction Control. My problem seems to be that the solenoid is not engaging and producing a vacuum, it remains off and allows air to flow through without allowing vacuum to EGR valve.
So far this is what I've done:
- Replaced vacuum lines
- Cleaned EGR valve and intake and exhaust ports
- Checked EGR valve by supplying vacuum at idle (RPM drops significantly = no clog and EGR works fine)
- Checked EGR solenoid (terminals are being supplied voltage around 5V at cold idle, continuity is within specs around 33 ohms, hooked up solenoid to 9v battery and it turns on and closes to hold vacuum)
- Checked Manifold Differential Pressure sensor (backprobed while engine on at idle and it is being supplied voltage)
- Checked vacuum lines running from EGR solenoid to vacuum control valve and EGR valve (all lines are good and hold vacuum and are cleared when blowing through them))
- Ran a live systems check using BlueDriver OBDII focusing on the coolant temperature sensor and it ran fine (start was 78 degrees outside temp and engine read 84 degrees, warmed up slowly at idle to 184 degrees and stayed there)
Does anyone else know of any other component in the EGR system that could alter the flow of vacuum? Maybe some other sensor that would fail and not tell the CPU to turn on the EGR solenoid? Or maybe even vacuum within the intake manifold itself? I took it to a shop a while ago and they said they tested for intake manifold leaks and could not find any so that shouldn't be it. Let me know if anyone has any ideas please.
1 - 8 of 8 Posts
Forgot to add symptoms I've been having with my car before code was thrown:
Rough idle when engine is warm and in drive (park idle is fine)
Significant condensation accumulation (water dripping under car)
Sounds like the vacuum port on your throttle body is not providing vacuum to the solenoid.
I checked those lines too they are supplying vacuum. Granted I am not sure if its enough vacuum, I'm gonna test that too with the hand vacuum, but there is a vacuum there.
Had a similar issue, egr solenoid was not closing completely when voltage supplied, car idled very rough. Pulled it out connected tube to it to blow through. Used a batt and some alligator clips and wire for 12v. I blew threw it, touched to terminals it would shut but not totally... so i gave it a good blow and guess i dislodged what ever was there. Tested a few times totally shut after that, which allows the vac to build and open the egr valve. Reinstalled. No issues since. I had a P0400 previous and very rough idle.
Not sure if it pertains to your specific issue but wanted to toss this out there for anyone interested.
On the passenger side of the motor, top left, one of the vacuum lines has a small piece of foam (I believe it's foam) and most either don't know, diagrams don't commonly show it, hose is replaced and new one doesn't have it in, etc causing issues. Don't lose that piece within the vacuum hose. It's required.
I can't recall if that's egr related, but I'm fairly certain it is.
Do you know which hose this is specifically?
2
The EGR restrictor is in a short hose with white markings, attached to the EGR vacuum control valve. Here's a pic of it's location on the 2000-2002, and another pic of the restrictor itself. You can push the restrictor out with a very small phillips screwdriver.
Note that a clogged restrictor is only one of several possible causes of a P0400, but it's a good thing to check.
Motor vehicle Car Hood Automotive fuel system Vehicle
Gas Audio equipment Automotive exterior Gadget Water
1 - 8 of 8 Posts
