1 - 7 of 7 Posts
RIPPerized
I keep getting a P2229 code which is an unidentified code. I was under the impression that there were no codes over 2000.
I've been getting this code for a while. I went to the dealership to get them to read the code. It came up as P0108 (barometric pressure) on their code-reader, so I have been clearing it under the assumption that it was a barometric pressure code. Yesterday I got both P2229 and P0108. So now I'm wondering WTF?
BTW, I talked to Ross about this, and he told me that someone else had gotten a code for high boost pressure. Apparently these ECU's are also used in some FI cars in other countries. Anyone able to shed some light into this?
RIPPerized
Yes, it's an auto. What do you mean by "vendor specific" code?
RIPPerized
BUMP. I put in the Zener diode. No barometric codes anymore, but I get the P2229 every time I get above 55 mph. And it doesn't matter how fast, or slow, it takes me to get there. ANY help would be greatly appreciated.
Boosted
obd2 has universal codes but they allow vendor or manufactuer specif codes in the P2000+ range for the vehicles
not sure if this one is or isnt though
EDIT
did a search and found other imports using P2229 as a code for P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage
I found the same thing - mostly in Honda's, though.
1 - 7 of 7 Posts
