1 - 3 of 3 Posts
I have look but can’t find anything I have cp forged piston and I was going to use my stock connecting rods. But I just found out that cp piston are clip style and I believe the stock connecting rods are press fit. Can I use the stock rods and press for them and then also install the clips or do I have to get different rods. And if I do what are some good brands to match with the cp pistons?
You can use semi-floating wrist pins with pistons that have grooves for full-floating wrist pins. Just don't use the clips. Make sure the semi-floating pins are the correct diameter for your piston.
1 - 3 of 3 Posts
