1 - 10 of 10 Posts
· Registered
since I am upgrading to 440cc injectors I am replacing plenum gasket, I picked it up today from the dealership and I just realized that there's actually 3 very thin gaskets, but when I took it off the one from the car; there was only one :confused: do I need to use all three?
This is the gasket btw (the long one) http://70.86.201.180/forum/showthread.php?t=52257
· Ah yes...
WanderingPinoy said:
The gasket I bought from the dealer was the same way, but they were all attached to each other. I should take a look at my old gasket. On a related note, do we need to replace that gasket every time we remove the plenium?
No you don't. I just put some regular motor oil to lube it up then put the lower manifold on.
· Patriot Performance
Guys those are the two lower intake plenum gaskets for the heads. There is one for the upper to lower section, then the two intake gaskets that mate on the heads. You only need the large one for the upper plenum ;)
· Kampfbereit
For his purposes, I doubt he is removing the lower intake manifold, just the upper. So effectively one gasket is in question here (not counting a TB gasket depending on how you remove the plenum)
1 - 10 of 10 Posts
