So the stars have finally aligned for me and I'm ready to start making single turbo kit piping. I'll be honest and Ken's post has prompted me to put a little more focus on this platform. Competition is good for the end user right? :bigthumb:
Here is the deal however. I'm not currently interested in selling an entire kit because I don't have the time or the ability to deliver the amount of support that would require. At this point in this platform's life, the information is out there about what to do and if you are serious about boosting this car I hope you've done your research. Honestly, the hardest part besides the tuning issues for putting a turbo kit together is the hot pipes. Ken was absolutely correct in that regard. The problem with selling just hot pipes is that your piping might or might not work depending on the turbo that the end user purchases. Turbos come in many different configurations, from different inlet flanges on the turbine housing (T3, T4, twin scroll T3, ts T4 etc) to different types of outlet flanges (3 bolt, 4 bolt, 5 bolt, v-band etc). The other thing is that you might have purchased a turbo that "meets the requirement" but it still doesn't work because turbine housings from different manufacturers are built to different sizes. Because of this, I need to know what YOU are interested in.
The 3G has seen turbo kits based off of either a T3 or T4 exhaust housing. The XTech kits used 5 bolt downpipe flanges with no wastegate port off the flange. AAI used a V band clamp for their downpipe. I've built kits for EVOs with just about every flange and I have to say that my honest to God preference is a V band clamp for the downpipe. Unfortunately, this comes at a price. A 2.5" V band clamp and flanges is over $70 while other flanges can be had for a fraction of this cost.
Another thing to contemplate is whether or not you want a recirculated or non recirculated wastegate. Honestly, I love the sound of an open dump and it's easier to plumb and fabricate.
So... Options that I need you to vote on so that I can start putting these things together...
T3 flanged 5 bolt housings w/ open dump (wastegate)
T3 flanged 5 bolt housings w/ recirculated wastegate
T4 flanged V band housings w/ open dump (wastegate)
T4 flanged V band housings w/ recirculated wastegate
These will be the only options I will consider making unless someone makes a very strong argument otherwise. Recirculating the wastegate will definitely drive the cost of the piping up.
Please note that my piping will be guaranteed to work only with Precision Turbos. Precision is the manufacturer of the turbo that we won a national championship with so I'm sticking with what I know works.
As an aside, I'm also willing to package this with a turbo so there is zero chance you end up purchasing a turbo that doesn't work with the piping. Pipe up and let me know what you think about that, pun intended!
As another aside, the downpipe I will make will bolt up to the stock catback. There will be no cat in the piping. One can be added either later, or if you inform me when at the time of purchase, it can be added for an additional cost.
A rough estimate of what just the hotside piping will cost is about $1000. Adding a turbo into the picture can bring this figure up to $1800 or so. This figure is not set in stone and may move up or down depending on my overall expenses and yes, I will be making some money out of this for my time.
I have a motor on a stand that I'm using to mockup the Y pipe. I would appreciate some feedback on the above options so that I can complete the initial setup and show you guys some pictures.
Greg
Greg
