1 - 9 of 9 Posts
Generally Bitter Admin
Motor Authority said:
Porsche’s new 911 GT3 Cup race car will be entering the 2008 motorsport season with engine output increased to 420hp (313kW), with the Porsche Mobil1 Supercup, Porsche Carrera Cups and GT3 Cup Challenges the first in line to see the new car compete. Only 265 examples are expected to be produced at the Porsche production line in Stuttgart- Zuffenhausen, marking a new record for a car of this category.
The most significant modification compared with last year’s model is the new rear end following the design of the production model. Air venting slits ensure better dissipation of heat at the rear. The 3.6L six-cylinder boxer engine developed in Weissach, Germany, is also based on the street-legal GT3 and develops maximum output of 420hp (313kW), 20hp (15kW) than on the previous model.
The sequential six-speed transmission with interruption of engine power enables the driver to shift up under full throttle without disengaging the clutch. The transmission itself has been optimized and the gear ratios adjusted to the characteristics of the engine. Weighing 1,150kg in race trim, the new 911 GT3 Cup has a power-to-weight ratio of 2.7kg per hp
db
if i remember right the gt3 is NA, which would be a fun car to drive. i would love to have a gt3 rs to drive everday. well, any 911 would be fun to carve up corners with.
More guns than sense
1150kg is like 2500lbs I think...badass indeed.
2530 lbs to be exact :shock: :yesway:
The GT2 is turbocharged. The GT3 and GT3 RS has always been normally aspirated and track-prepped.
1 - 9 of 9 Posts
