If power brakes work under vaccum, what happens under boost?
Mivec is variable valve timing. Where talking about varible length intak runners.Bitter said:hmm i saw a Ripped GTS at btn5, the first ripped GTS. the mivec on it worked....
ya a window switch would work great tho, and then you could control the rpm at which mivec engaged![]()
Are you sure? I always thought mivec=vtech? Variable valve timingBitter said:i know mivec is the intake runner, with the reed valves.
ask ripp?
that first line is kinda hard to understand... :ugh:
nope mivec is a set of reed valves in the GTS manifold that change the lenght of the intake runners dependent on rpm and throttle. higher rpms the valves give the air a shorter path so the engine can breathe better. at lower rpms a longer path for more torque. well thats come to be my understanding of it. lets see what google says!Chase2000gt said:Are you sure? I always thought mivec=vtech? Variable valve timing
With that said, The runners probally wouldnt switch under boost, even if the solinoid was activated.NAPALM said:1)
If the check-valve is working properly your brakes will feel firm and will require more foot pressure to stop the car when you step on them under boost(basically feels like the car is off). If the check valve is not working properly(letting pressure into the brake booster) the brake pedal willl feel rock solid and your brakes will require an emense amount of foot pressure to stop the car.
your probably right, rig up a magnetic solonoid on an rpm window switch. a servo may even work. but a solonoid would probably be easier to fit and work faster and more reliablyChase2000gt said:With that said, The runners probally wouldnt switch under boost, even if the solinoid was activated.
I thought about a servo, but speed is definatly an issue.Bitter said:your probably right, rig up a magnetic solonoid on an rpm window switch. a servo may even work. but a solonoid would probably be easier to fit and work faster and more reliably
There is a set of long and a set of short runners. Its changes from short to long, or long to short @ a certain RPM. Ill take a picture or twoNAPALM said:Doesnt make sense....................:scratch:
Usually the idea is to open up the runners at close-to WOT to allow more air to flow into the combustion chamber........
yea so it can breath better at high rpms but still have tq at lower rpms.NAPALM said:Doesnt make sense....................:scratch:
