Absolutely....so its fine if i unscrew the whole sub and check behind the sub for the wiring?
Don't "mess" with them, just be sure they all have good connections.ya idk how to check if the wires are loose or hooked up...they are hooked up to the side of the box to the amp...
so im guessing the other wires are from the inside.....and WHICH I do not wat to mess with
Awsome suggestion guy, I was just about to say the same thing! :bigthumb:Don't "mess" with them, just be sure they all have good connections.
Try this to mount your sub...
Parts Express:Cast Frame 1/4"-20 Speaker Mounting Kit
You won't have the problem again.
