1 - 16 of 16 Posts
ok i was leaving work last night and went to shift into second and the car started missing really bad. i had let off the gas and everything as soon as it started missing. Ichanged the plugs today and chaged coil packs still has a miss any ideas??? :dunno:
if its missing then it has to be throwing a code. take it and have it scanned at autozone or advanced and see what the code is.
Just a thought here. did you track the wires back all the way or just from the coil packs? Could be something as easy as a loose wire running to the packs.
Could be a fuel delivery problem. Try using some fuel injector cleaner. If that doesn't work, maybe something is wrong with the fuel pump. Just a shot in the dark, since all cylinders are missing and all cylinders get fuel.:ugh2:
Sounds like a rotor and cap issue.
1. Did you change the rotor and cap?
2. Did you replace the spark plug wires and put them back in the correct order
3. Did you recheck to make sure the wires where tightly seated?
4. Did you possibly leave something unplugged?
Try reseting the ECU.
Cyberbrain, it is an RS, they are DIS. No Cap. Also, Check the Fuel Pressure Regulator. If there is low pressure to the injectors, it would cause similar issues to what you are seeing now
1 - 16 of 16 Posts
