Well its quite easy.
The way i done it, I moved my drivers seat all the way back, layed in the floor board with my head towards the front. looked at the OBD plug that way. The first pin is in the main left on top is the one you stick the wire in, then get in the seat, close the door, scoot your seat up so you can touch the steering column under the dash, hold it to that. Press the hazard lights six times, it will unlock then lock.
Thats when you program the remotes. Make sure on each remote you only press one button, and only one each. Or it will fuck up and you will have to start over. Then when your done take any one of the remotes and press a button twice any button. Thats when the programming sequence is over.
Remove the wire and try the remotes...Should work. Make sure you remove the key first of course.
