I am Installing a pyrometer(EGT) with my SDS. I am Installing a GTS upper intake manifold and the Ripp New design headers. to my understanding Ripp slightly legthened the #4 pipe to help counter the lean condition with the standard GT intake manifold. My question is what is the best Cyl to tap for the EGT useing this setup?
Really, Even with the even length runners and longer #4 tube? I would think that #4 would run a little richer due to the headers design. I could be wrong but thats what i'm trying to find out. :confused:
New daddy
You have made changes to your car, so of course no one is going to know for sure. However, cylinder #4 is known to chip first with other setups. This is where I put mine.
Kampfbereit
Cylinder #4 and #3 are the cylinders that run the leanest and prone to detonation simply because of the uneven runners in our intake plenums.
Tap on the tube of Cylinder #4 for now, but once you get a Diamante or a GTS plenum, that becomes less of an issue.
