As some are aware I road race the clipse! Also know that I'm one of the few on here that does so but needed to ask!
With that said I'd like to impart a couple of on going issues I have been having!
First, my water temp doesn't go over 130, ya I know not good, ( car seems to run fine) but as I'm told it probably is running richer than need be because of the cool running. What I'm thinking of doing is pulling the thermostat & run it that way just for grins & giggles. If it still runs cool then I may pull the radiator & fans & install a much smaller radiator without fans.
By the way I do have a gauge installed & also have moved the pickup to two diff. locations with the same result. Even though I have low mileage the thermostat may be stuck or just plain no good! Anyother ideas?
Next issue, depending on turn taken, mostly carrousel right or quick left/ right turns I invariable have trouble, (not all the time but enough to where I have to pull off course to settle the car down to find gears).
Now with that said, I have Prothane mount insets, the Ingalls stiffy, & brass bushings on the shift pickups! Any possible ideas on this would be greatly appreciated, don't know what else I can do? Was going to disassemble & atleast coat the posts with anti-seize but don't know if this is the answer.
Any help would be appreciated & will reply to all! Thanks in advance! :twothumb:
