1 - 2 of 2 Posts
· Registered
So last night I rewired in a radio to see if it would work and 2 wires said white/black ones for a speaker and the other is a 12 volt accessory and I connected both of them to the white/black wire I go connected the car battery and the car turned on by its self so I disconnected the speaker wire and its still doing it so I disconnected all the wire and took the radio out and I tried starting my car, it started fine but it reved to 1k rpms at cold start instead of 2k rpms and I tried giving it gas and instead of if revving it bogs out and goes under 1k rpms and wants to die, if you know how to fix this please let me know
· Super Moderator
Sounds like you screwed something up trying to install that radio. With that radio uninstalled...check all your fuses, both inside and under the hood. Also check to see if there are any burnt wires ... Could you add a picture of the harness from the back of the radio you were trying to install?
1 - 2 of 2 Posts
