1 - 20 of 21 Posts
Vehicle: 2003 Eclipse GTS
I decided to install all urethane bushings in the rear of my Eclipse. I knew it would not be an easy task. Here are some items of interest that I did not find on the forums. I would think this thread pertinent to anyone planning this task. This is not a how to but more of an informational thread. There are some very nice "HOW TO" threads in the garage. All pics/movies below are thumbnails and may be enlarged.
I read on the forums that the rear suspension on a 2g Eclipse and a 3g Eclipse were very similar. I was told that the 2g Eclipse Prothane rear control arm bushing kit would work perfectly and would actually include more bushings.
I’ll explain, but I actually had to buy two kits to replace all the bushings with the proper parts. I had both the Prothane 3g rear control arm bushing set 13-302 and the Prothane 2g rear control arm bushing set 13-301 in my possession during this process.
[URL=http://s198.photobucket.com/albums/aa312/buddhalawton/Eclipse%20Rear%20Suspension%20Mods/?action=view&current=DSC01044.jpg][/URL]
Lateral Link / Toe Arm / Tie Arm:
Everyone I spoke to or chatted with called it something different. I’ll call it a “toe arm” for sake of this post. This is where my problems began. There are two ends to this arm, an inner and outer:
The inner end attaches to the car via a through bolt and nut. After pressing out the old bushing my first problem was discovered. I was going to use the inner toe arm bushings from the 2g Prothane kit because they were not included in the 3g kit. They were obviously much smaller than the original.
I thought this a minor inconvenience at first as I could easily make a bushing that would fit the arms larger outer diameter. That’s when I started digging into the differences between 2g Eclipse and 3g Eclipse toe arms. The 2g Eclipse and 3g Eclipse FOUR CYL cars use the same toe arms as each other, NOT the SIX CYL. The 6 cyl 3g Eclipse (gt or gts) use toe arms which are not only different in part number, but different in the way they work as well.
The inner toe arm bushing on a 2g Eclipse and 3g Eclipse 4 cyl is a “simple bushing.” Basically a very hard piece of rubber with a steel sleeve through the center. The 3g Eclipse 6 cyl uses an actual swiveling joint. It’s similar to a ball joint in the way it can move. It has a much greater range of movement than a simple bushing. There is also no flex in this joint like you would find with a rubber bushing. It’s very rigid, hence no need for an after market bushing.
2g and 3g Eclipse 4 cylinder simple bushing:
3g Eclipse 6 cylinder pivoting bushing:
See the pivoting motion:
4 Cyl vs 6 Cyl toe Arms:
If I modify the 2g bushings to fit my toe arms, it will greatly hinder the arms ability to work properly. So at this point I know I’m stuck with some bushings from the 2g Prothane kit, I can’t use.
The outer end of the toe arm has a ball joint that is pressed in and secured with a clip. This ball joint attaches to the knuckle with a locking nut.
Ball Joint Removed from Toe Arm:
The entire front end of the car has Moog suspension components (ball joints, inner and outer tie rod ends, sway bar links) already so I wanted to replace the factory Mitsubishi rear toe arm ball joint with a Moog part. I could not find a Moog ball joint to fit this application. I looked and looked for suitable replacements. I went to my local parts store and looked at ball joints for 1g, 2g, and 3g Eclipses. Front, rear, top, bottom, FWD, AWD……it didn’t matter. I could not find an exact match. I’m not saying it does not exist, but I couldn’t find it.
So if I want to replace the outer toe arm ball joint and the inner swiveling joint mentioned above, I’ll have to buy the entire arm and choose between an aftermarket and a factory Mitsubishi arm, right? Wrong.
It’s been mentioned on the forums that people have replaced their factory toe arms with some made my Dorman. This is fine if you have a 3g 4 cyl, as that is what they are designed for. The Dorman toe arms I found should not be used on a 6 cyl 3g Eclipse. When searching Dorman’s website, they don’t even list a toe arm (they call it a lateral link) for a 6 cyl. Why? No swiveling inner joint. They would probably “work” on a 6 cyl but I sure wouldn’t install them.
I ended up using brand new toe arms from my local Mitsubishi dealer for about $65 a piece. If you own a 3g GT or GTS I see this as the only way to do the job correctly as the engineers didn’t put a swivel in for no reason. Now I have a new ball joint and inner swivel.
Upper Control Arm:
Both the 3g and 2g Prothane rear control arm kits come with upper control arm bushings, but there is a difference between the kits. The steel sleeves that come with the 2g kit have a much thicker wall thus the inner diameter of the bushing is larger to accommodate.
In reality you could use either style in place of each other. There are probably some hardness differences between the 2 kits, but as far as installing is concerned they would be identical. Just be sure to use the correct sleeves with the correct bushings. I ended up using the UCA bushings that came with 3g Prothane kit.
Lower Control Arm:
The lower control arm is pretty straight forward. Using the bushing supplied in the 3g Prothane kit, they install per the directions. The 2g Prothane kit has these bushings supplied but like the toe arm, they were the incorrect size.
Trailing Arm:
Both the 2g and 3g Prothane kits come with the trailing arm bushings. The bushings supplied with the 3g kit are one piece and the 2g bushings are 2 piece. Again, probably some hardness differences, but both could be installed no problem. I used the bushings from the 3g Prothane kit.
Knuckle:
The knuckle bushings are only supplied in the 2g Prothane kit. The two lower positions on the knuckle take a different part number bushing than the upper position.
It’s hard to spot if you’re not looking but they do have a different part number and slightly different shape.
(I’m told that the lower knuckle bushings will also work for the upper position, but it’s a tight fit. The lower bushings are available on Ebay and have been tried by others in the top position)
There were some bad burs on the knuckle that I dressed to fit the new bushings properly.
Before:
After:
In conclusion, you’ll have to buy both the 3g kit and the 2g kit to complete the job unless you can source bushings individually.
Hope this helps. If you would like to see a ton more pictures go here:
Eclipse Rear Suspension Mods pictures by buddhalawton - Photobucket
Manual Swapped!!
Good writeup but there is no need to buy the 2G kit as the knuckle bushings can be bought individually and the 3G kit has the upper, lower and trailing control arm bushings. It is nice to have confirmed proof that the toe arm bushing CANNOT be replaced.
Manual Swapped!!
Yea I see that but I have not come across 2 different toe arms between the models, albeit I did not search hard. I get my parts through RockAuto and they only had 1 style :dunno: the toe is adjusted the same, on the same rear subframe, with the same specs. So now my GS has a swiveling joint. I checked it after you posted that in the rear knuckle bushing thread
Discussion Starter #7
If you search for the "toe arms" at rock auto for a 2003 Eclipse V-6 it doesn't show any parts available. Dorman doesn't list any on their sight as well.
Chuck Nasty
:agreed:
i have worked on several v6 and 4 cylinder 3g eclipses and have yet to see one not using a swivel rear toe control arm or "lateral link" as rock auto calls it. maybe a 2000 rs will use it but i doubt it. the 2000's are a botched up year. for example on kinko's car he bought stock replacement front control arms. well the 2000 uses a one piece construction bushing in the rear whereas the 01+ uses a bushing on a shaft with a nut on it. the one with the solid bushing is damn near impossible to install and if you do it you better be the damn hulk because a 4 ft pry bar wasn't enough for either me, courtney, or my coworker to get it on. although the 2g rear is VERY similar to ours you must remember there are differences. the 3g is where many upgrades were made such as stronger control arms, different lower control arms, different sway bar routing and thus endlinks.
anyways props for the write-up though, at some point i may do this upgrade myself especially since is doesn't seem all that bad.
Discussion Starter #10
Just spent some time on CAPS. This is for the LEFT SIDE. I called my local dealer and checked to see if any of the part numbers below were superceded. All below part numbers are valid and available:
ALL Eclipse GS use MR162571
ALL Eclipse RS use MR124293
ALL Eclipse GT and GTS use MR325255
So yes, there is definately a difference between the V6 and 4 cyl toe arms. I was doing some research and found these pictures by Beriant.
The 2g Prothane rear control arm kit toe arm bushings will not work for a V6 model Eclipse. The four cylinder models use the small simple bushing and the gt/gts use the larger diameter swiveling bushing.
(These pictures also added to the original post)
V8 > 3G
I purchased new toe arms from roackauto and they're obviously listed under the 4 cyl. Am I going to run into any issues putting these on my V6? Doubtful but I thought I'd ask since you have both there are your shop.
Currently I can grab the toe arm on my car and twist it forwards and backwards very easily with the suspension loaded.
Judging from the pictures, they look identical except for the body pivot point. They both appear to share the same diameter/length sleeve. I'm gonna put a prothane bushing in my arms anyway so I'm no concerned with anything performance wise.
Chuck Nasty
the ones listed at rockauto are only pivoting ones. they don't sell the rubber bushing ones
V8 > 3G
Anyone have any insight into this situation? I plan to start re-doing the entire rear suspension on my 3G as soon as the rain stops. I basically just wanna know if the I4 toe arms are interchangeable with the V6.
Hello..
Great post.
My issue is i got a 2001 galant ES. I need to replace the rear upper knuckle bushing ... and not sure which kit to get ... searched a lot on ebay .. and they all seem to be for 94-99!!
Are they the same? anyone knows?
Hello..
Great post.
The 95-99 GST upper knuckle bushing kit is the kit you need to get.
T-Money is T-Money
There is no reason why you could not install 4 cyl toe arms on the v6.
The only differences in the v6 and 4 cyl that I'm aware of is.
Rear disc brakes
These toe arms
And MAYBE sway bar thickness(not sure)
I'd bet they used those swivel bushings for the disc brakes.
The toe arms should only need to swivel if the wheel were to move forward or backward from it's stand still position which could be caused by the disc brakes grabbing better. When I took my drums off at 80k miles the friction on shoes were like brand new and they held easy with little e-brake lift so they def don't engage as well as the discs.
With that being said, when you replace all the other bushings that tend to flex especially that front link from rear knuckle to the body(keeps rear wheel from moving back and forth) it will all be much more solid and not needing that swivel.
Think of it like this
4 cyl with full prothane rear suspension and disc swap
Will be exactly the same as
6 cyl with full prothane rear suspension using 4 cyl toe arms with prothane bushings
Hope this helps
I've been having trouble with figuring out this problem that I ran into with the Rear Knuckles, because I don't know what exact source to get the bushings from and which ones to use clearly, even with rapid research through the forums.
When I was in College studying for Auto Tech, I had bought two whole kits and never finished replacing all my bushings two years ago.
but long story short my rear knuckles are completely gone; so the kits that are still in my possession apparently never came with the knuckles at all, which leaves my vehicle out of operation and I'm about to just go grab the whole knuckles from a junk yard for 45 bucks per arm which I don't wanna do.
I own the 2000 GT 3.0.
Look in the photobucket account link above. He has a picture with the part numbers for the knuckle bushings. Take those numbers and google to see if they still are offered.
1 - 20 of 21 Posts
