1 - 8 of 8 Posts
Sebring 6G72
What kind of pump pressure do you guys run on your meth kits?
what size nozzle?
It is a dual stage right? where it comes on less at start and linear to full spray?
Sebring 6G72
Discussion Starter · #2 ·
Do you guys really not know this stuff that is on your cars?
THis is the second post where i asked specific questions that noone knows an answer.
Sebring 6G72
Where was the snide remarks?
Ripp uses the Snowperformance boost cooler and the pump only goes to 140psi unless you upgrade to the 220psi. Is this what you use the upgrade or is it really 140psi?
so which nozzle?
Im running the 225.. I also have the 175 and 375..
I got my kit from snow before Ripp worked with them...
Sebring 6G72
So you run the 225 at 140psi? or did you turn yours down a bit?
1 - 8 of 8 Posts
