1 - 15 of 15 Posts
Here is every thing I have so far for my car (haven't bought anything yet) I would love and appreciate more input from you guys (before I make a move)...:wavey:
As few of you may know (from my previous threads) I want to make this engine look as badass as possible...:agreed:
http://i.imgur.com/8pXftxO.jpg
Here is all I have so far (feel free to tell me what you think):happysad::
Amazon.com: QP CT021-c Mitsubishi Eclipse Replacement Coolant Tank: Automotive
Amazon.com: SET OF 6 BRISK PERFORMANCE SPARK PLUG Replaces NGK IFR6B-K - w/ 360-degree electrode SWTPEPG54476: Automotive
Amazon.com: NGK (8711) ME97 Wire Set: Automotive
Amazon.com: TBK Timing Belt Kit Mitsubishi Eclipse 2000 to 2005 3.0L: Automotive
Amazon.com: Spectra Premium CU2410 Complete Radiator for Chrysler/Dodge/Mitsubishi: Automotive
Amazon.com: Monoprice Cable Tie 4 inch 18LBS, 100pcs/Pack - Blue: Electronics
Amazon.com: Burnt Tip Stainless Steel 4" Tip Catback Exhaust System+Silencer for Mit 00-05 Eclipse 3G: Automotive
http://www.amazon.com/gp/product/B011O1U634?psc=1&redirect=true&ref_=ox_sc_act_title_27&smid=A23OTYJ080R5GI
Amazon.com: HPS Cold Air Intake Kit 00-05 Mitsubishi Eclipse V6 3.0L Blue: Automotive
http://www.amazon.com/gp/product/B00P64CBXE?psc=1&redirect=true&ref_=ox_sc_act_title_26&smid=A23OTYJ080R5GI
Amazon.com: Evergreen PSBR5030/0/0/0 Mitsubishi 3.0L V6 SOHC 24V 6G72 Engine Piston Set Main Rod Bearings: Automotive
http://www.amazon.com/gp/product/B00MYG5LDO?psc=1&redirect=true&ref_=ox_sc_act_title_25&smid=A131HE22U4WT5U
Amazon.com: Upgr8 Universal High Performance 12V Slim Electric Cooling Radiator Fan With Fan Mounting Kit (12 Inch, Blue): Automotive
Amazon.com: Universal T6061 Aluminum Power Steering Fluid Reservoir Tank Black: Automotive
Amazon.com: Spectre Performance 29846 Blue 3/4" x 4' Split Loom: Automotive
Amazon.com: Power Stop K1683 Front/Rear Ceramic Brake Pad and Cross Drilled/Slotted Combo Rotor One-Click Brake Kit: Automotive
Amazon.com: 2020-FS - SENSEN Shocks Struts, Front Set, Lifetime Warranty: Automotive
Amazon.com: 2020-RS - SENSEN Shocks Struts, Rear Set, 2 Pieces, Lifetime Warranty: Automotive
Amazon.com: KYB SM5091 Shock / Strut Mount Kit: Automotive
Amazon.com: Cartman Roadside Emergency Kit Set, Booster Cables 6Ga x 16Ft UL Listed + Tow Rope 4500Lbs, in Carry Box: Automotive
Amazon.com: Upgr8 Universal 4mm/6mm/8mm/12mm Inner Diameter High Performance Silicone Vacuum Hose Kit (Blue): Automotive
Amazon.com: Mishimoto MMHOSE-3G-00BL Blue Silicone Radiator Hose Kit for Mitsubishi Eclipse V6: Automotive
http://www.amazon.com/gp/product/B00CJ6J6Q2?psc=1&redirect=true&ref_=ox_sc_act_title_15&smid=ATVPDKIKX0DER
Amazon.com: SUNDELY® Blue Color Glassfiber Exhaust Pipe Header Heat Wrap Resistant Downpipe Tape Roll 2in X 16ft (5cm X 5m) + 5 Metal Ties: Automotive
Millrose 70660 Monster Roll PTFE Thread Seal Tape, 1/2-Inch x 260-Inch, Blue - - Amazon.com
Amazon.com: No.1 Windshield Sun Shade, Cool FREE Product Included With Sun Shade - A Powerful UV Ray Deflector, High Quality Car Sunshade To Keep Your Vehicle C...
http://www.amazon.com/gp/product/B00GSAUHB8?psc=1&redirect=true&ref_=ox_sc_act_title_12&smid=A2JO65GM85V5J4
Amazon.com: Royal Purple 10-2808 Oil Filter: Automotive
Amazon.com: Spark Plug Ignition Wire High Heat Boot Protector Cover - Blue 8 CYL: Automotive
Amazon.com: Road Power 989 Anti-Corrosion Fiber Washers, 2-Pack, 6 and 12-Volt: Automotive
http://www.amazon.com/gp/product/B000CQFS0O?psc=1&redirect=true&ref_=ox_sc_act_title_9&smid=ATVPDKIKX0DER
Amazon.com: Schumacher BAF-2 Battery Post Shim: Automotive
Amazon.com: Genuine Mitsubishi Battery Positive Terminal Connector MU800889 Galant 2001 2002 2003 2004 2005 2006 2007 Eclipse 2001 2002 2003 2004 2005 2006 2007...
http://www.amazon.com/gp/product/B00R9SWUS6?psc=1&redirect=true&ref_=ox_sc_act_title_7&smid=A1SZ6UU4D3JXAA
Amazon.com: Rockville R4G150B 4 AWG Gauge 12 Feet (Cut from a 150 Foot Spool) Blue Amplifier Power/Ground Wire With Braided Super-Flex Design: Car Electronics
TEMCo Welding Lead & Car Battery Cable WC0190 - 30' Black/Red (15' Blk, 15' Red) 4 Gauge AWG | MADE IN USA - - Amazon.com
Amazon.com: Absolute USA ANL120-2 2 Pack ANL 120 Amp Gold Plated Fuse: Car Electronics
http://www.amazon.com/gp/product/B00GN5IUP8?psc=1&redirect=true&ref_=ox_sc_act_title_4&smid=ATVPDKIKX0DER
Amazon.com: Digital Positive Battery Terminal 8/1/0/4 Gauge And Volt Meter: Automotive
Amazon.com: E2 by Scoshe EWFH Single ANL Fuse Holder: Car Electronics
Amazon.com: Premier Gear PG-13886 Professional Grade New Alternator: Automotive
SIDE NOTES:
1)The piggy bank is about $2,000..;);)
2)I know is a long thread and I'm sorry for that but this being an Mitsubishi Eclipse forum I see no where else to turn...:scratch::scratch:
3)I hope you guys along with your experiences will help me...:):)
4)I've only had this car since October 2015...:eek3::eek3:
5)I will appreciate your time and input to the maximum...:wavey::wavey:
6)Sorry for my English, as it is not my first language...:rolleyes::rolleyes:
Thanks to all in advance...:happysad::happysad::happysad:
MAAAAADDDDD
dayco timing belt with pump and hydraulic tensioner : rockauto.com and if im correct, it's only 180.
sensen struts? never heard of them, anybody here use them or comment on them? id go with trusted, commonly used ones.
the spark pulgs are nice, but you wont see any power upgrade from them. so just run of the mill plugs would do fine
if you want good looking, get the machined radiator mounts from a thread here on the forum, and get a mitsumoto radiator. you can skip the heat boots as the will be hidden inside the plug tube, and you should save some money getting a dayco kit from rock auto. other than that, sounds like you are trying to relocate the battery to the trunk and a huge pair of subs.
A nice car cover
A nice car cover to keep the moisture from interior and exterior paint and stuff.
If you have the cracking dash thing, so can get a "dash cap" to pop over your current one here. Accuform Plastics Inc.
Wish you well with your project.
Goal
what exactly is your goal for the car? it looks to me like you're throwing parts at the motor and seeing what sticks once the dust settles.
My goal is to buy all new...:eek3:
I bought the car used so I don't want any more issues with it...:rant2:
If I can give the engine more power while making it look new and clean than thats what'll do...:yum:
Discussion Starter #6
Thanks for your input...:wavey:
Truth is that couple of the things in there I pick them because no other things would ship to P.R.:rant2::rant2::rant2:
So I went with what I found (that also shipped to P.R.)...:dunno:
But thanks again...:wavey:
Discussion Starter #7
Thanks but the Interior and Exterior aren't a priority right now...:rolleyes:
But will do keep that in mind...:yesway::yesway:
Thanks...:wavey:
Those spark plugs are crap. With the manifold blocking the rear bank it's best to change things once and be done back there. Do the valve cover gasket and tube seals at the same time as the plugs and wires so you don't need to go back in there again.
Use these plugs.
http://www.amazon.com/Denso-IK16TT-Iridium-Spark-Plug/dp/B00TPU8OT0
Some stuff on your list makes no sense.
Where are you going to put the spark plug heat sleeves?
What's wrong with your current pistons and bearings and why would you just get OEM replacements?
Don't you want to replace the missing strut tower bar?
You have an OEM positive terminal and an aftermarket positive terminal?
What do you need a universal cooling fan for?
Why buy Sensen struts when you can get Koni or KYB?
Etc.
It really looks like your just put eclipse in the search bar on Amazon and picked all the blue parts that popped up.
Anduce
Hey man, I saw you said PR. I am here in the south, add me up, just in case you need parts ,I know a few people who has junked their eclipses,
creo q seria mas facir decirte,Si te puedo ayudar me dejas saber.:yesway:
also, I added a few parts for my wish list XD
Discussion Starter #10
Use these plugs.
Etc.
To respond to all your questions in one answer, its because Im limited on the things that do ship to PR... Other cool and better things wont ship to here...:rant2::rant2:
I wont buy things locally because here people wont only want my money they will also ask for a leg and maybe an eye :lmfao:(Economy here aint too good and shops and stores prices here are outrageous):eek:...
And yea:lol: I want my engine to look blue-ish:lol::lmfao:
Anything else you wanna point out, please do, all feedback is welcome...:wavey:
I still haven't bought anything...:happysad::happysad:
Discussion Starter #12
Thanks Bro, will do...;)
1 - 15 of 15 Posts
