1 - 20 of 259 Posts
MIVEC?
I bought this car in may 2007 and up until this month i have been slowly working on it. Nothing special :
-Cold air intake
-Megan race headers
-Diamante manifold and throttle body
-Greddy SP2 cat-back
-NGK 8mm plug wires
-Stock calipers painted blue
-EBC rotors and yellow stuff pads all around
-KYb AGX struts up front
-Relocated stock battery to the trunk
-Ingalls torque dampener
-Lambo door kit
-Plasmaglow multi-color led underglow kit
-Misc. engine dress up (blue hoses and harness)
Pics:
Then i decided to go all out and try to cram a 3.8 6g75 from an 07 eclipse into it. So far the only person in the world to attempt this on a stock computer. I drove about 2 1/2 hours to pick this thing up from the scrapyard.
Its from a 2007 eclipse with almost 1000 miles on it. Nice lookin engine if you saw what was left of the car it came out of.
Tear down:
Out With the old
And in with the new:
The finished project:
Here are some of the parts that had to be modified for the swap:
First and most obvious the ignition issue was solved by using the distributor from the 6g72 with spacer in place of the stock 6g75 cam position sensor. The mounting location:
Mocked up, as you can see there is a need for another 1/2 inch of metal in there.
The plate that was made to fill the space.
The location of the distributor is now in the way of the waterneck. It had to be modified to fit:
Also the 75 has no sender for the coolant temp gauge so the one from the 72 needs to be added.
Next up is the crank position sensor. This is a direct swap from the 72. Swap over the sprocket and the sensor itself.
from the 75
from the 72
The stock 75 fuel rail does not have a return as on those cars it is built into the tank. So one needs to be added.
I chose to cut mine up and make it with the return on the other end of the rail for equal pressure across all the injectors. Not necessary i just did it for future FI plans.
The throttle body needs to be swapped also as the 75 uses drive by wire so its all electronic. I used the diamante one i had from a previous project. There is no place to mount the throttle cable on the 75 intake manifold so i made one using the egr solenoid mounting bolts. You may notice the orientation of the TB 90 degrees from where it normally is. This was for clearance issues.
The EGR solinoid on the 75 is also electronic so you must use the one from the 72 it is a direct fit.
More pics and info as i get time to post it up.
R.I.P. silverside
I hope this works out. Post a video of the start up if you can please. Any plans for forced induction?
Bankai
correct me if im wrong on this but doesnt pharm already have this motor in our platform and its up and running?
I think you are right. It's in his 2g Stratus I believe, but I'm not sure if he has it up and running yet...does he?
Shut up.
The last time i read, he didn't have it running yet. He was still waiting on some parts and his EMS to get back from being repaired.
Good luck, keep us updated!
Bankai
I thought that was the case. Even so, definitely a LOT of work to do a 6g75 swap. Well... a lot of work in general for engine swaps.
MIVEC?
Discussion Starter #9
Pharm is also doing this swap but he is using an ems whereas i am using the stock 3g computer. So far we are both waiting on parts and neither has started the car yet.
And yes any swap requires a lot of work but this is feasible IMO for someone that would attempt the 6G74 swap. Its a bit more expensive though.
Yes the plan is to turbo next year the way i had originally planed on this year. I even have two turbos laying around that i bought in January.
MIVEC?
Discussion Starter #11
:agreed: looks to be an assload of wires to deal with
:lol: Believe it or not the wiring is done now and that was one of the easier parts to this whole thing
Bankai
Well I hope everything turns out well for you and pharm. Thumbs up to both of you for doing the swap.
FearIsTheMindKiller
I don't think it's possible to run this engine on the stock computer. But I hate to be a naysayer. Prove us wrong! Good luck with the project :)
:yesway:
MIVEC?
Discussion Starter #17
:fawk: I was able to get it to start without the waterneck i only let it run for about 2 min, Just to see if it would. It ran like s*** though its not getting enough fuel for some reason.:dunno: I should have a vid tomorrow after i get some tuning done.:lol:
TxTuning.com
good luck with it. After watching over Pharms thread I don't see only using the stock computer either. Keep everything detailed, thanks.
MIVEC?
Discussion Starter #19 (Edited)
I have pics on all the parts i swapped and made to make it work. Im not gonna post them till i have mine 100% done.
And like i said over there i cant run the mivec with the stock computer. I have Greddy for that issue. Right now it on a ricer switch till i have the money for the MSS
1 - 20 of 259 Posts
