1 - 10 of 10 Posts
Wondering what the gap should be on the sparkplug gap, my motor is stock besides the exhause/ t3/t4 turbo kit and stage 3racing clutch... should i stick with the stock size or resize it to a smaller incriment? anyhelp would be great because im trying to get her to run today and that is one of my problems.
You should also get a colder heat range spark plug.
I've found that if you are 10psi or less you can go to .035. If you go over that, I had to reduce to around .030 to prevent the boost from blowing out the spark.
I had a leaking fuel injector when I first installed my injectors. I found out that after you tighten the fuel rail down, you can't rotate the injectors at all without ripping the o-ring/grommets. Cheap part to replace but a pain in the @ss.
Straight from RRE's website
" Spark plug gap should be set at .030" for up to 16psi boost. Set at .028" for 17psi and up. "
Reactions: Chato
1 - 10 of 10 Posts
